Buying an affordable furler.
Charles, Don't rule out buying a used upper end furler. I have two Harken units on my boat, a #1 & a #0 and found the #0 used by digging around (the #1 came with the boat). At the time I was told that I'd never find one used which I simply took as a challenge. The bottom line is that there are used units out there and if you look for a high end used one, chances are that they'll either be in excellent shape or need few if any readily available parts. As it turned out, the used one I bought ($400.00 as I recall) was in perfect shape and even now after many, many years, it still performs flawlessly. Begin your search by visiting the Consignment list at the Good Old Boat Magazine on-line site but don't rule out a thorough local search as well, the latter being how I got mine. With most things I buy regardless of application, I use as my guiding principle that I buy the best for the job because I only want to buy it once. So in your case, consider buying a good used unit and you'll probably only buy that one and not have to replace a lesser one on down the road. Good luck, Glyn Judson, E31 hull #55, Marina del Rey, CA
