Akavishon
Few days ago, I noticed that one of the bolts holding the port-side rope clutch (serves jib and spinnaker halyards) is leaking ... I took it out, then noticed that the wooden block which the rope clutch sits on is in bad shape - the forward edge (in the direction of pull) has started to crumble and disintegrate.
The truth is, the 'easylock' rope clutch is old (though still working fine), and according to rigrite.com somewhat undersized for the E32 (it's recommended for boats up to 26' LOA). My first idea was to replace it with a new clutch, but that would mean fabricating a fresh wooden base (bigger, sloped etc) which is beyond my abilities. Whichever new clutch I'd pick, it would require drilling new mounting holes ... well, it gets messy. I got plenty of projects this spring already, so ideally I'd like to fix this with as little effort as I can get away with.
So I'm thinking - maybe apply some wood hardener to the injured wood, build up with hardened epoxy, then redrill and remount the old clutch?
Your opinions are asked for ... maybe someone has a better idea? What's the right thing to do here?
TIA - Zoran
TIA - Zoran
