While I have my mast down for some refurbishing, I've been contemplating my running rigging and seeing if I can improve the efficiency of my setup and the control lines running to my cockpit. Maybe I can bounce some ideas around to those of you more experienced for your thoughts?
Here's my current layout:
Port
Jib Halyard - furling; internal mast
Whisker topping lift - external
Reef #2 outhaul - internal boom (Jiffy)
Main outhaul - internal boom; fixed foot main
Starboard
Main Halyard - internal mast
Reef #1 outhaul - internal boom (jffiy)
Vang - run through block and back to cockpit through organizer
Main sheet - internal mast
Ideas:
Thanks!
Port
Starboard
Ideas:
- Move the whisker topping lift to be internal and still route it to the cockpit. Setting a whisker pole is a 2-person operation for my boat, and that other person is typically in the cockpit already.
- Add an internal masthead line that can be used as either safety line for mast ascent or spare halyard.
- The jib halyard gets used 2-4 times per year. It seems like overkill to have that running to the cockpit. Any reason I shouldn't relocate that to the mast, add a rope clutch or cleat to tie it off there, and store it in a bag attached to the mast until needed?
- I almost never adjust the mainsail outhaul. Is that common, or should I be doing it more? My main is pretty blown out, so I'm not sure how much magic sail shape could actually be accomplished here. I currently have to put some strong tension on my first reef line (leech) to improve sail shape today.
- Other lines handy for the cockpit? Reefing downhauls? Boom topping lift?
Thanks!
