Roger Ware
My Ericson 38 200 has the following alarming characteristic that I have had to deal with at least once in every one of the 4 seasons I have owned the boat. When I sail my boat in more than 15 knots of breeze, and the boat is heeled at greater than (as a guess) 40 degrees or so, it fills up with water! When I say fills up, I don’t mean a couple of buckets in the bilge, or even 20 buckets in the bilge, I mean water sloshing around the inside of the boat, well above the level of the floor. Yesterday I was pounding in 25 knots for several hours I would estimate several hundred gallons came in, to a level 2 or 3 inches above the floor. As soon as the boat is horizontal, the incursion ceases.
Here’s the other fiendish twist. Every time this happens, the electric bilge pumps, all two of them, refuse to operate. To be precise, they are running, and one of them at least was running noisily and continuously, but not one drop of water gets pumped out. Not one. The only pump that I can get to work is the manual bilge pump, which exits from the same thru-hull as the other pumps.
Having read some Ericson 38 stories on this site and others my first thought was the bathroom thru-hulls, sink drain, toilet intake etc. But at least in most of the subsequent “flooding events” these were all closed.
In my second season it happened again, but by this time the boat was clearly leaking, even when horizontal, but from a obvious source, the hull-keel joint. So I spent a few more months fixing that, and naively assumed that the “heavy weather flooding” problem had been fixed also.
I was also distracted by the condition of the electric bilge pumps, which seemed to work fine except when I really need them, when the boat is flooding, and then they pump absolutely nothing. So I replaced those, even though now I think that they probably were working fine.
Here’s my latest (and only current) theory, supplied by a friend: the bilge pump thru-hull is back-filling (no check valve I think, at least not on all routes into the bilge). Why, I don’t know – and this is a huge amount of water to be flowing through that bilge pump hose (and the thru hull is pretty far back on the port side of the hull) But, would this somehow explain the mysterious breakdown in the electric bilge pumps? If this is happening to me, surely it must have happened to someone else on this list? It really is a nightmare.
Thanks to anyone who has an insight into this.
Roger Ware
Kingston, Ontario
Ericson 38 200 "Starlight II"
Roger Ware
Kingston, Ontario
