ted_reshetiloff
My autopilot on the E-38 does not seem to work. It has not worked since I have owned the boat. (4 months) It has power coming to it. All of the buttons seem to work. It will turn the boat when engaged by pushing the turn bottons. What it will not do is hold the boat on course when in the auto mode. It never makes any adjustments to course and the boat just goes off course. I have tried to calibrate the fluxgate compass in it per the instructions but the calibration never seems to be accepted by the unit. The manual says to make a slow right turn with the unit in calibration mode. If the strbd led lights you need to increase speed of rate of turn. If the port led lights speed it too high or turn too sharp. Idea is to keep both lights happy during the procedure. I have tried this several times and the strbd lights stay on telling me to speed up or turn sharper which I do but it never seems to be enough to trip the port led and after 4 minutes I get the alarm telling me that the calibration has failed. I have calibrated the unit for the number of turns from lock to lock. Anyone have any experience here? Everything appears hooked up correctly and I assume the unit worked for the PO it does not look very old or worn. It is a very simple unit only requiring power and ground. I guess I can uninstall the unit and send it back but what a PITA.
