Rocinante33
Frank,
Another helpful bit of information to guide you in rig tuning is located in the Specs & Docs section for the E-33. It is in the #2 owner's bulletin included there. Like your 30+, my 33 is a fractional rig. This bulletin came from an expert at the factory (Don Kohlman) at the time of production. It does not list specific tensions you should use, but does provide a stepwise process toward achieving the proper tensions on the fractional rig. Make sure to look at the diagram on the last page to be clear on the terminology he uses.
These documents were aboard my boat & Sean was kind enough to add them to docs. It probably is not where you would think to look for your boat, but I think it is relevant.
Good luck,
Good luck,
