Anton,
I'm not sure exactly what you're asking. Our boat is a 1984 E30+, our propeller is a Brunton Varifold two blade geared folding prop installed by a previous owner in 2001. It's a 13 x 9 RH prop, with prop walk to port. I spoke with a propeller shop which recommended a 15 x 9, but there is not enough clearance under the hull/rudder for that size.
The prop walk can be strong and a bit annoying, but I've mostly learned to work with it and use it to my advantage.
When backing up I initially give it quite a bit of throttle, but then put it in neutral and turn the rudder in the direction I want to go, then put it in reverse again with less throttle until it "grabs" and I can feel the boat move where I want it to go in reverse. It took a while for me to figure out how much throttle, when to shift to neutral, etc.
I hope this helps, but let me know if I haven't answered your question.
