My 1982 E38 is on the hard. I've owned the boat for a year, and there's always been water in the bilge, so I'm concerned about the state of the keel bolts and bedding. Therefore, I've started the process of removing, replacing, and re-torqueing the keel nuts and washers. Of twelve total, the five nuts in the aft portion of the keel have been replaced and tightened (bolts are in good shape). The next two forward (just behind the mast step) and the single forward nut have been removed and water is seeping up around the keel bolts. I've probably sucked up a quart of water with my shop vac and it just keeps slowly seeping out. My only explanation is that the keel shoe is saturated and removing the nuts relieved the pressure, allowing the water to seep upwards. Remember -- boat is on the hard.
Can anyone think of a way to dry this out? I'm thinking of drilling into the keel shoe, allowing it to drain and dry, then refilling the hole(s) with thickened epoxy.
At this point I am not going to drop the keel -- the rig is still up, and I'm not ready to go through the pain and expense of taking it down this year.
To prevent future ingress, I have ground the keel joint down to bare lead and fiberglass. The forward portion of the joint bedding (looks like old 5200) appears degraded, so I have cut it out with my Fein oscillating scraper blade, and I will re-calk with 5200 Fast Cure. After that I intend to glass over the whole joint with epoxy and a couple layers of 6" biaxial fiberglass cloth/mat tape. Then I'll fair with Total Boat TotalFair epoxy fairing compound.
Thoughts?
Thanks everyone,
Vaughan
Thoughts?
Thanks everyone,
Vaughan
