Enroute home after buying our new-to-us '76 E36C, we discovered a very small leak in the water tanks located under the cabin sole. It is a small leak, but fast enough to fill the bilge in two days. The problem is that there is NO ACCESS to the tanks, other than two small pull out pieces around the mast or ripping out the sole.
Has anyone replaced their original water tanks, how did you do it, what do you recommend replacing them with (plastic, stainless, etc), how can we keep the cost down (hahaha)?
