Seth here......
It does not really add more area, but does add depth..And while it is true to some extent that you want a fuller shape when reaching and running because you are heeling less and therefore can beneft from the added "power" of a fuller mainsail (which is why you often see racers easing the outhaul when sailing off the wind), there is a limit to the effectiveness of this technioque, and in fact it often makes you slower..
Why?
When sailing downwind, and there is no attached flow on both sides of the sail, the only thing you have going for you is maximizing projected sail area. Easing the outhaul does make the lower portion of the mainsail fuller, but REDUCES projected area-because you are shortening the foot of the mainsail.
In breezy conditions at deep angles I generally will ease the outhaul only an inch-if at all. On a reach, and provided we are not overpowered, I may ease a little more (but on a reach you still have attached flow, which is always more effecient than sailing ddw without attached flow).
I use the analogy that easing the outhaul is akin to reefing the mainsail (an exaggeration of course, but it makes the point)...The thing to avoid is easing the outhaul too much-the "baggy" shape some sailors like to see is rarely fast....This is a very common mistake.
Back to the zipper-in the 70's and early 80's some sailmakers used this device as a sort of flattening reef-zip it up when it is breezy to flatten the sail and reduce heeling- it gets you a little more flattening than you can with just the outhaul. When sailing downwind, if you unzip it, you can add some depth to the sail WITHOUT shortening the foot (and hence avoid reducing projected area!).
In the end, this device has gone the way of the flattening reef-more trouble than it was worth. A properly designed mainsail will have enough shape range with the basic controls (mast bend or tune, halyard, cunningham and outhaul)..
Since you have this and are keeping the mainsail for the time being, the decision wheter or not to use it depends on the overall shape of the sail. If the sail is quite flat to begin with, you may want to keep it unzipped in light air (up to maybe 10 knots TWS), and above that just leave it zipped and keep the sail flatter-a flat sail allows more air to move across its' surface and creates more lift-the trade-off being that in light air you may need more power in lighter air; more depth creates more power, but also creates more drag. The power/drag ratio works in your favor in lighter air with chop, and begins to slow you down (for several reasons) as the breeze builds..
If the sail is fairly full to begin with, I would leave it zipped most of the time..
Hope this helps!
S :nerd:
