    2024-2025 Fund Raising Info
E32-200 Keel Bolt Replacement
After removing my keel from my boat as part of my hull fiberglass repair, it was revealed that my fore and aft keel bolts had weathered excessively.
isbwrMqTESnxeSPvzvV4UGZV5ZhJ2uuTQ2Du9EBkjB8ZFzAXYH8urwmspUF273WsCSCBimh0mh4nUJngVCzkxCYHh8xl7IMnD6aC2VTVOxiDoz_9kJVCV9lWEIM2le9UMGw6mN-C
CJJine2aJXbQgV-uj09ZAcXzMkmgSAIg1ZcSCBmaVq8e96Nz_VGlDM0DUfMXbKOcnnsTv5Zd1gScV0GN63QgvY4KZM-5ZXlQqlAtM_us0ZO9EZdrZW3d_K4Dfl7TXOR4EpcZPoaU
For the forward bolt, given the slope of the leading edge of the keel, the yard decided the best way to effect a repair was to drill out the old bolt, then cut out a notch to insert a new bolt.
vY_g6mZMFt_A7swLdlQ6Pk0Bwj1lkyltUtJfhSn-6wncVtweDGOQryZNNpkJLEmBwaj9qPtGcuXAONEulgUAHt0rqSMANnbLvKkH_s4lxOEa1tfXYV5YKZr8avyehBpvxE6w0F69
The old bolt was a J shape, the dangling portion of which will remain in the keel block:
27zqAiPWZUOrRVFIv_d-dGSmquCDgL9wiBanB3ZE3dd__9dgXNskLBm6AF5eMQNpx5DHjs_ijB6ioRcLlE9oKgaEuDs_6QeqUl6qljTwFNEc-jZ35_3eITXWtLoWbcSTLZyF8Vpt
A new through-bolt was attached from beneath and epoxied in place.
_FS_TwUrDcdjtnKQZIrsu7UDzmUunaU0pr2HIkbCFs3mHzOPHkfPlybrVnAV728RdNC2gk3hsM0ROHz_Q2nBp-4SS_SAheRRVGhaYgNLNYU2FLgFXW1jEluM4ut4qETjsec4c5fV
This bolt connection was then epoxied/faired:
oBYv9-H5auEOGeeqrbRkfcS4eIa-LJMlt7Ax1L9o5DvY4e7H9x5MJScuvU5lQf5LXP3VkNDj-mMz_bKDpSQ8BYMkbZ6drVJw3gZECBxHGXFjHZalHmblcKIXm-a3YqkFS5XyDDB2
For the aft bolt, the weathered connector was drilled out and a round piece of stainless steel bar stock was drilled and tapped to serve as a holding nut. The fabricated nut was then epoxied in place. The new bolt is wider than the OEM Ericson bolt it replaces.
4hO-ILkX9A04vNA8tHoeSYc_J-TKE9mypkV6BaMpoEWQLc4VoDsUovCcpwqS0FXTYX0mrE_tedg_esDR167i_IwR3mE_mRf2IvZtfTX6Hhd8DJXGHFkcF_W0y2eybY-_7OTjydgs
After what has felt like a very long time, the keel is now ready to be reattached to the boat. The question remaining is whether the connection will require an epoxy bedding or whether generous amounts of 5200 will suffice. So says the yard, anyway.
LZ7iAPomW7VXbduAD7rHP59xRRoKsjGgL-RYLzmuzMAAK4H_tRcg7k5C5k3EGsJD3ErPYhVcV07F_gs6p8UobIH4ADDyqSazwumMhAE00HD-Y9MFkFT3Ax1_RI-Zg8U4fJvSY3Nz
Last but not least, the substantial ding I took out of the bottom of the keel by hitting a rock at 7 knots, has been cleaned up and faired:
svhHl0Jy-vsXTyCfb4ckkU73-hMC-JKanWPJXvL3STLRFV7M-gF2FJzSHi8aAIlomvf9RKvQGgFAsHwuGKRqCA1SGAW6jYjSZ9uBCR2lUGpHq4qMR4lbcnlsI-U7m9krsMLhTLJT
  • Like
Reactions: Christopher Smith
Blog entry information
Author
goldenstate
Views
1,209
Comments
11
Last update
More entries in Hull, Deck, Keel & Rudder
More entries from goldenstate
