Ted,
Did you have a space in your keel joint? What exactly did you do to repair the joint? Any pictures?
I was thinking of sungging up the joint as good as I can, and then grinding down the joint, and fiberglassing the joint with thickened epoxy and cloth, fairing, barrier coating and painting. It might make it more difficult to ever drop the keel, but it should seal it good and tight.
My joint is pretty tight except for the leading edge which I can get a putty knife blade into or a small screwdriver. I have filled and faired for 5 years now and am getting tired of the same old repair in the spring, which is why I was thinking of the glassing route.....
any opinions or suggestions concerning my plan, or any way to improve on my plan?
Todd
