SeaDog said:
Thanks for the quality information. I called the folks at Jamestown today and they are great! I do have two remaining questions. What kind of sealing compound should I use? I could not find bronze tees. How do the plastic or nylon hold up? Are they "safe" for below waterline use?
Kirby
Uff Da, Ericson 32
Alamitos Bay, California (Long Beach)
Hi,
check back on these two links for bronze T's etc. You can get all the bronze and red brass (nipples will only come in red brass) from either Jamestown or Hamilton. Since both sites are huge, here are direct links to pages you can browse from:
At Hamilton:
http://store.hamiltonmarine.com/browse.htm?id=100&step=2
and for Ts sepcifically, look under the catagory of "Bronze Pipe Fittings"
At Jamestown:
http://www.jamestowndistributors.com/to;ID;,Marine.Plumbing,Bronze.Fittings
and on page right, they have bronze T listed seperatly.
Do note that it is important to use compatible metals - e.g. don't screw bronze seacocks to backing pads with stainless, use bronze
Jamestown has a nice little metal compatibility chart. Check it out here:
http://www.jamestowndistributors.com/decoder_compmetals.jsp
BTW, this is under JD's tips section, which has tons of good info:
http://www.jamestowndistributors.com/decoder_index2.jsp
As to sealants, I would recommend 3M 4200 for most applications. I do use 5200 on bronze below the water line, but do this with the understanding that you are creating a near permanent bond that will either require 20+ years of time or heat to break it free. I would not use 5200 on anything other than bronze below the water line for these reasons. Whenever I've mounted transducers, which seem to all be a reinforced type plasic material these days, I use the 4200 so there is a chance you could remove it if needed. For work above the water line where UV is a factor, take a look at 3M's 4000UV. It is very similar to 4200 in performance with UV protection.
OK, and now that I've written the above, I realize you meant what we often refer to as "pipe dope". Here's a link to Oatey's site and one of many products that shoud work (and I've used this stuff, for what it's worth, which ain't much...)
http://www.oatey.com/apps/catalog/showskus.asp?ctg=80&subctg=0&prodgrpid=90
To me the pertinent information on this product is as follows (I copied this from the link above):
Lubricates and seals all threaded joints.
White, non-hardening, non-separating, non-toxic paste.
Withstands up to 3,000 PSI on gases from -50° to +400°F, and 10,000 PSI on liquids from -50° to +500°F.
For use with water, steam, caustics or dilute acid lines of PVC, CPVC, ABS, cycolac, polypropylene, iron, steel or copper.
I think that as nasty as salt water is, it falls within the above parameters
You can get this at your local hardware store.
-David
Independence 31
Emerald
