Kim Schoedel
Yesterday I noticed the bilge pump cycling about every 10 minutes or so.
The hose under the cockpit has a split in it. So I closed the through hull under the sink and it stopped the leak.
I had my son, much smaller and younger than I, do the monkey thing and crawl down into the starboard lazerette to inspect. It appears that two of the drains are routed down from the cockpit to a "T" behind (aft) of the hot water heater to a single hose that then routes forward to the through hull under the sink. This single line is has a 1 inch split in it and when the through hull is open it is shipping lake water to the split.
Obviously, I need to replace the hose. But why would the water be flowing in reverse from the lake? The design is to drain water from the cockpit to the lake. Not the reverse. I have never had any problems draining out before. could there be a check valve between the "T" and the drains in the cockpit?
Please help, I don't get it.
