Sparky84041
I’m a new E-27 owner, and it appears I have a Cutlass bearing issue. The bearing has separated from the strut, and will need to be fixed. I assumed I just need to attach to the brass (?) casing to the strut and all would be good; however, all the pictures that I have seen – it appears there should be a casing around the bearing attached to the strut. This doesn’t seem to be what I have. The brass casing will slide along the shaft without any resistance. Does the Cutlass bearing go inside the brass casing? Am I ok to reattach (weld), the casing back to the strut?
Oh, and from the picture, you’ll note I’ll be needing a new prop.
