Hi all, when we got our E27 a few years ago one of the PO’s had removed the toilet and holding tank. We have been using a port a pot but now I am ready to reinstall a jasco head. i have 2 questions. 1: what is under the head ledge (for lack of a correct name)? Our boat has no access to that area and I assume there is plywood or something to screw toilet to but I don’t want to assume. Question 2: I can tell by the holes in the bulkhead that’s there was no loop above waterline. We are a Great Lakes boat and there is no through hull for waste. It is a closed system just head, holding tank and clean out. Also a vent. Since there is no through hull for waste do I need the loop? It does not look like they had one originally. Is there a compelling reason for me to install one? Thanks in advance _/)
tpcorrigan
1976 E27 “Big League”
You should find ample strength in the plywood below your “head-ledge” but your plan to add a bit more strength and height is a good one.
The original head in our ‘73 E-32 didn’t have a water intake loop and the water would seep up and just over the bowl rim to flow onto the cabin sole. Of course we simply shut the intake valve off after each use but had the head sat a little higher it would have been above the waterline when at dock or anchorage.
In our refurbishing, we added a 1/2” thick additional plate plus another 1/2” narrow piece under the head. Now it sits with the bowl ABOVE the waterline. Instead of wood, we used PlasTeak as it’s less susceptible to water damage over time. The flooring/sole is now covered with PlasTeak flooring, again for ease of care.
Like you, there was no vented loop on the intake and I opted not to put one in this go-round. The waste hose exits through our sink cabinet and then to a Y (since we still have a now unused thru-hull) and on to our holding tank installed in the V-berth storage.
We use grey water from the sink drain Ericson hooked up just in back of the raw water intake.
Here’s some photos of the various stages of our project. (We cut a larger hole around the head ledge so we could install a new thru hull. Another reason for the PlasTeak cover plate.)
A LOT of work but now that it is done it was worth it.
