I have a 1976 E29 with a 150% on a roller furler. I also have a 100% jib that i would like to use when the wind picks up. My question is which genoa track to use for the #3. My shrouds are all the way outboard at the sheer, With the primary track outboard of that. When using the outboard track, I cannot obtain a good sheeting angle to use the #3 jib upwind effectivly. When I use the inboard track on the fwd cabintop, the sheeting angle is poor because of the fwd shroud is in the way. How do you other E29 owners rig your #3 jib? Would it be poor form to run the sheet aft between the Fwd lower shroud and the Upper shroud? Solutions and comments appreciated. Does anyone have the dimensions for a good #3 jib? What configaration do you other E29 owners use in 18-20 knots with a sloppy seaway?
Thanks for your reply
