I would appreciate some help in locating the wiring connections for the lights on the mast (deck, steaming and anchor) at the mast base. None of these lights work on my 1984 E30+, and the bulbs look ok (I know that's no guarantee), but there is no power at the bulbs, so I'm thinking it may be the ground wire as none of the three lights is getting power and I think it's unlikely that there is a loose connection in each of the positive wires. There are four wires--a brown, a yellow, a blue and a black, which I presume is the ground for all of them.
I have found the wires for these lights under the headliner by opening the zipper in the head near the compression post, but although the wires are there, they disappear as they approach the mast area, without sign of any connections.
I have sounded the compression post area in front of the mast (inside the cabin) and it sounds hollow, so I'm wondering if I remove the teak board on the front of this panel (there are bungs/screws), whether I might find it there?
There is no access through the mast above the deck (ie. no evidence of a plate or opening).
I think I recall someone telling me a while ago that the only access to these connections is by pulling/raising the mast, but I'm hoping there might be an easier solution.
If anyone has any experience or advice on where this connection might be, please let me know. Otherwise, I have no idea how to get these lights working again.
Thanks for any help on this.
Frank.
Frank.
