Meanolddad
Regalus has decided to try to sink. The bilge has had a bit of water when we would go sailing. Now it has quite a bit of water. I pulled everything that I could out of her and looked for the leak. It is coming from somewhere between where the prop shaft enters the boat and the rudder. I crawled all over the rear of the boat and pulled the blue prints and cannot figure out where the boat is leaking. The through hulls for the cockpit drains are not leaking, the rudder post is not leaking, the water is coming in further to the rear than the prop shaft entry. Regalus is a very stock boat so there has not been many modifications since she was built. I am going back tomorrow to start really pulling her apart. It is salt water that is slowly coming into the bilge. With the way she was built with the interior being dropped into the hull it is hard to find the source.
Any suggestions would be greatly appreciated since Regalus has no shore power to power a 110v automatic bilge pump.
Greg (MOD)
Greg (MOD)
