Hi Paul,
The answer is neither. Just like modern deep anchor wells, I made a 3/4" hole several inches from the bow on the port side of the new locker bottom draining directly overboard. I put a stainless cone shaped vent over the outside hull side pointing aft and slightly downward to prevent dirt collecting there.
The original drain thru the front edge of the bow is several inches too high to use as a primary drain. I'll just leave it there. I noticed some of the newer deep well boats have a bottom drain as well as a "high water" drain in case the bottom drain gets plugged or can't keep up I guess.
Shadowfax said:Neal,
Does your new chain locker drain into the bilge, or have you reused the orginial drain?
