Geoff,
The Frog Princess is a cold molded custom boat. The
larger stretch version will be a glass production boat.
Moisture meter readings are valuable during the dry
out prior to barrier coating. When done over time,
they indicate relative dryness such as above and
below the waterline for example. In my view,
water intrusion into a FRP laminate is a problem
and should be arrested to get maximum hull
lifespan.
To bring this discussion back to the original point-
I feel that all the boat prep in the world is
worthless if the global strength of the hull is
compromised enough to fail when encountering
loads found offshore, and the damn thing sinks
right out from under you. Wouldn't you agree?
Regards,
Martin
lifespan.
Regards,
Martin
