Hi All,
Apologies if this is rehashing another post. I pulled the trigger on a simple Jabsco hand pump compact and now I'm trying to decide on a Ronco holding tank that I can fit in under my main cabin salon starboard berth seat and then run the pumpout hose to a deck fitting near the chainplates for the shrouds. Does anyone have any experience with installing? I'm looking at the B217 and B218 models to fit the countour of the hull. I do not want to have to cut out the frame to fit it in, so maybe I'll go smaller. Ronco customer service mentions I can get up to three fittings included in the price. Planning to go for the 1.5" waste in line, 1.5" waste out line, and a vent fitting. Any recommendations on vent hose and the size if I'm running it 15' to the transom? Any value in a waste out deck fitting with a built in vent in it, or running two vents to generate cross flow to promote good bacteria? I'm going to ask to add an inspection fitting for cleaning as well. Ideally I can get the fittings from Ronco and make sure they're top quality. Will give them a call after I figure out my dimensions and strategy on tank size.
I'm somewhat of a novice on the proper fittings and hoses, if there are any pro's who have been down this path before, I would greatly appreciate any advice. I am planning for anti siphon loop for the salt water intake, but do I also need to add an anti siphon loop for the waste line from the toilet? Part of me feels like that's a big ask for a manual hand pump toilet to push waste up hill before going to the tank.
Thanks in advance!
- Rob
Thanks in advance!
- Rob
