treilley
Boy, she sure has pretty lines.
If you have to remove the pullpit and pushpit I would get some thickened epoxy, overdrill the holes down to the inner layer and then pot them. This will keep the boat watertight during transit and you should be potting those holes anyway to prevent future water intrusion into the core.
I know you have your hands full so a good temporary solution to cover those holes would be to use foil type duct tape.
Electric is good for coastal cruising but if you ever plan to take her offshore for any extended period of time, you want diesel. Electric propulsion will only push your boat so far until needing a recharge and you could not have enough solar or wind generators to do this in the water. I know that the batteries recharge when sailing but ask any cruiser who has crossed an ocean and they will tell you they had times when they needed to run the motor for days.
