Hi,
I want to rebed the bow pulpit and cleats, and can't really get at them from the underside due to the anchor locker being in the way. There is very little space between the anchor locker and the hull to get my hand and a wrench in there to the underside of the deck.
I am thinking it would be an easier job to rebed all the fittings if I can take out the anchor locker. On examination, it looks like it is held on place by about 24 screws from the top, through the lip and into the fibreglass. Most of these screws are currently underneath either caulk or silicone, but I think I can scrape that away and get them out.
However, on examination from below, it looks as if the anchor locker is also caulked into place with two different kinds of caulk--one is clear and looks like silicone, the other is white and looks "goopy and solid"--I am worried it might be 5200.
Even if I can get the screws out, there doesn't seem to be a way to get a tool like a putty knife between the anchor locker edge and the underlying lip--ie the two parts that are caulked together--to pry them apart.
In doing a search on this site, some reported that it was a very tough job, others said it wasn't so bad, perhaps depending on what was used to seal the anchor locker. Can anyone provide any advice on how I can best get it out--tools to use to get between the two lips and to pry it apart without cracking the fibreglass anchor locker.
Any other ideas on how to re-bed the bow area without removing the anchor locker might also be helpful.
