Hello All,
We are keeping our '83 E38 in the water over the winter. The question is what do we do with the cockpit drains that empty through the thru-hull underwater? I understand keeping the cockpit covered to minimize water/freezing. The two above waterline drains are not my concern. I am worried the below waterline drain may freeze and burst the drain hose. Do you close the seacock and pour antifreeze in the drain line? Do you leave the seacock open and let any water in the cockpit drain? Either way, I see a freezing risk for the drainhose/seacock. Any ideas appreciated, Thanks, RT
