In Use Report
For all you composters...
Here is some more info from a friend that is using one of these in his 36 foot boat (albeit not an Ericson). Posted here with his permission. He read over this thread and sends along these thoughts:
"I have had my 'Air Head' composting toilet for 3 years. It does not require an external heating source as long as the ambient temperature remains at 64 degrees or higher. The heat from fresh fecal matter along with the composting action helps to maintain temperatures above 64 degrees. I can go an entire boating season without emptying the fecal matter reservoir.
The liquids container, however, needs to be emptied approximately ever other day. I carry an extra liquids container. Since our primary cruising ground is the Columbia River, we anchor out or find a marina to tie up at night.
When staying at a marina, I make it a point to empty the liquids container in the marina restroom. At the end of boating season (November) I detach the unit and bring it home to disperse composted material on the garden. I must say that of all the things I have purchased for my Cascade 36 sailboat, the 'Air Head' composting toilet has been the most rewarding.
My only disappointment has been that once the season is over there is actually very little composted matter to spread over the garden, as it cooks down to almost nothing. As long as one follows the installation and operating instructions, there should be no problem with the unit.
Happy sailing,
Chuck"
Happy sailing,
Chuck"
