Sean Engle
Your Friendly Administrator
Administrator
Founder
Hi Sean,
I suggest adding, "Ron Holland" after the 33 as it is for the 36 II
Thanks or taking this project on! For all you do, You are a wonder!!!
Thank You!
Done - thanks!
@Christian Williams , I will contact you separately about the E38s and will also reach out to @Glyn Judson on the E36s and E31s... If anyone else has any info on any of the production runs from PSC, please advise as we're still missing much. WIP version of the accompanying table for this document is shown below.
//sse
Model No.AKACompanyProd StatProd EndHIN StartHIN EndTot ProdComment
23MK1Ericson Yachts196819701165165
23MK2Ericson Yachts19741979201470270
25MK1Ericson Yachts197219781384384
25MK2Ericson Yachts19791984501693193
26MK1CrealockEricson Yachts196619691190190
26MK2PacerEricson Yachts1967196811111
26MK3Ericson Yachts1984?200??
26MK4300 SeriesPacific Seacraft1987?300??
27MK1Ericson Yachts19711979113021302
28MK1Ericson Yachts1980198450159494
28MK2Ericson Yachts1985?600??
29MK1Ericson Yachts197019792626625
30MK1Ericson Yachts196619701150150
30MK2Ericson Yachts1977197914747
30MK3Pacific Seacraft1979?501??
31MK131CEricson Yachts1976197812726Hull No. 13 was not produced
31MK2IndependenceEricson Yachts19781981287144
32MK1ScorpionEricson Yachts1967196712424
32MK2Ericson Yachts19691978101573473
32MK332-200Pacific Seacraft1985?601??1985-1990
33MK1Ron HollandEricson Yachts1981198412828
34MK134REricson Yachts1977197812121
34MK234TEricson Yachts1977197910114141
34MK3350Pacific Seacraft1986?201??1988-1990
35MK1Ericson Yachts1967196814545
35MK2Ericson Yachts19691981102612511
35MK3Ericson Yachts19821998111??
36MK136CEricson Yachts1975197716666
36MK2Ron HollandEricson Yachts1981198413232
37MK1Ericson Yachts1973197515353
38MK1Ericson Yachts197919871126126
38MK2380 SeriesPacific Seacraft1993?1986-1990
38MK2381 SeriesPacific Seacraft1982198650153939
38MK3382 SeriesPacific Seacraft1985198620023031
38MK3Pacific Seacraft1987?231??
39MK1AEricson Yachts197019791106106
39MK2BEricson Yachts1974197820122121
39MK2SMEricson Yachts1971????
41MK1Ericson Yachts1967197015050
46MK1Ericson Yachts1971197422322
O25Olson 25Ericson Yachts1984130
O30Olson 30Pacific Boats19781984250
O34Olson 34Pacific Boats198619861
O34EOlsonEricson Yachts1988199039
O911SOlson 911Ericson Yachts19871990?
Total Hulls Produced:5610
Sean Engle
Administrator
Founder
Continuing... Just got out of a conference call with their counsel and the Chamber.
It appears that what will likely occur is that the Chamber is going to set up an online certification acquisition system for these hulls, within the existing confines of the system they already use (SWIFTDox). That is, issuance of Certificates of Origin will come from the Greater Chamber of Irvine, and will be issued on a per-hull/per-owner basis or if a single owner has multiple Ericson hulls (no 'blanket' certificates will be issued). Those included will be all of the Ericson, Ericson-Olson, and Ericson-Pacific Seacraft family of hulls.
To do this, I will pull together a packet which will include documentation on HINs, production numbers, corporate/production history and statement of the authority of EY.o (in support of the certificate), as well as instructions on how to pursue/process the certificate. Owners will download this packet, and combine it with additional needed documents, including a copy of the hulls bill of sale and likely some affidavit of ownership, plus possibly one or two other documents, and along with a process payment (currently $150 per certificate). The owner will then go to the website, and upload all of this, including the payment, and the Chamber will issue a Certificate of Origin in digital form, on the SWIFTDox system, which is a common documentation portal for customs offices.
There may be an option for some kind of a hard document; that will be added to the inquiry. We are still in the process of determining what this packet will look like and consist of. I am also in the middle of exams so I won't be able to look at this until sometime next week at the earliest.
At a minimum, this should provide the documentation that overseas Ericson owners are looking for when seeking to register their hulls. In addition, it should provide a good body of knowledge and documentation for new owners in the US to answer the common questions about HINs and when what portions of the Ericson line were produced when. In short, it's a positive outcome.
I'll let you know more as it happens.
//sse
Thanks a bunch! We have no current plans to document our boat, but it would be great to have that option for the future.
Dave G.
1984 E30+ (SOLD)
Great work Sean ! Question, in looking at the list above the 30MK3 (30+) is listed as Pacific Seacraft ? I think that should be EY no ?
jtsai
I have always been puzzled by my 1990 Ericson 32-3 with the 760 hull number. The hull VIN clearly identifies being an Ericson boat but the year and hull number fall within Pacific Seacraft 32-3.
william.haas
1990 Ericson 28-2
Hi Sean... if you could update the spreadsheet the second iteration of Ericson 28s were produced (I believe) from 1986 to 1990. I have hull 712 manufactured in June of 1990.
I am confused. I have not believed that there were any PSC-built Ericson's prior to early 1991. Thru 1990, the HIN should show the Ericson Yachts code (same for the Olson 34, 911, and 25, that they were producing). I could be wrong, however......
Sean Engle
Administrator
Founder
You're correct on this, although the numbering scheme they used looks more similar to PSCs than the ERY original... I have updated the sheet.
Sean Engle
Administrator
Founder
Update:
I just had someone IM me on this issue, so I thought would update all of you. What follows is a paste of the text from that conversation which outlines what the issue is (for summary purposes) and what it's current status is.
//sse
Issue there is the creation of a Certificate of Origin (CO) - which is a document usually provided by the manufacturer to attest to the item in question having been manufactured in a particular country - for purposes of assessing someone VAT or excise taxes when attempting to bring it in to a second country, etc. Without the CO, the holder of the vessel (in this case) would be subject to all kinds of nasty taxes and fees and would have difficulty proving where the vessel actually originated from, actually having the boat registered and insured, etc.
Since Ericson Yachts as a business is defunct, this was difficult for some of our owners who are located outside the US. So, I am working with the Greater Irvine Chamber of Commerce in California (COs are usually stamped by the Chamber in the jurisdiction of origin) to create a path whereby any owner of an Ericson Yacht can go online to their jurisdictions website, enter in some documents and a processing fee and have a CO issued by the Chamber. EY.o has basically stood in for Ericson Yachts, Inc. to provide the basis by which that document will be issued.
This past Friday (05/07/21) I sent off a final draft of documents to their General Counsel who is reviewing it, and soon we should be uploading an entire packet of documents to the site which these owners can use to get the CO issued for their boat, and put all of this behind them.
Mr. Scarlett
Bit of drift from the original question but as far as importing an Ericson sailboat into Canada from the US all that was needed for customs was a bill of sale with the boat's HIN, and a copy of the sellers certificate of ownership. They wanted to know more about the outboard for the dinghy that was included with the sale.
Hope this is useful for somebody.
Curiosity...... Did you have a signed-off former state registration to also hand over? Or, a copy of the former state title?
Mr. Scarlett
I'd have to look closely, as that's what I may be referring to as a certificate of ownership. My last boat was not very well documented from about 1977 onward. I was as guilty as other previous owners at keeping it up to date.
The paperwork is another system I'm familiar with but need to learn to maintain in my case.
Along with autopilots
and watermakers,
and roller furlers,
solar,
blisters!
And who knows what else? The boat arrived four days before I had to go to another two week stretch at work.
Alexa Jane
Update:
//sse
Hi Sean— I am in process of documenting my E37 with the Coast Guard and have run into a block of providing a builders certificate. I’m looking at a lengthy and expensive waiver for not providing this. After a long conversation with a long time Coast Guard documentation employee it was indicated I could provide any kind of documentation From either a former employee or some business like association with Ericson. In short I just need to prove that the boat was built in the US. I’m very interested in the work that you’ve been doing with the city of Irvine can you update me as to the status of this ?
Many thanks, as I just received my endorsement from the Coast Guard I can happily sign off as Captain Alex !
Alexa Jane
Yes I am referring to the certificate of origin process/ documents you mentioned as being in front of general counsel on May 7, 2021 and whether we could get the certificate from the Chamber of Commerce in Irvine California
Alexa Jane
Hello — just inquiring about the status of this with the City of Irvine - regarding certificate of origin?
Thanks!!
Alex
Sean Engle
Administrator
Founder
Thanks!!
Alex
Just responded to your IM on this. Please email me directly. We are in the process of finishing up with them and you'll likely be the first to use this service.
UPDATE: We are nearly complete on this and are working out the final logistical issues (signatures, where documents reside, etc). It appears we have our first victim, er...volunteer, er....applicant... who will run this the first time and help us sort out any remaining issues... I will update you all again when I have more info.
:egrin:
//sse
