treilley said:But shouldn't the length of the line be based on the foot of the sail?
bigtyme805 said:I am telling you, riggers say 1 1/2 times the the length of boat. I had a new roller furling put on 8 months ago with a new 150 and this rigger I employed to put it on decided to go with what he deemed enough line had to replace the line because he shorted it by 2ft. I asked him what happened and he said that he had some extra harken line and he really thought it would work. That is when we got into the discussion about the length of the line.
Diameter was discussed on this subject and I remember using 1/4in line.
Emerald said:OK,
...So, instead of us all second guessing on an unspecified brand of furler as to what would work, call the manufacturer and ask them! You'll get the right answer, and if you want to then play with different diameters because of your hand comfort etc., you at least have a starting point of what the unit was designed for, and if you ask the tech guy the right questions, you might find you have some room to play.
I don't mean to be too crusty here, but let's get it right the first time and not make it more difficult than it needs to be (like buying 50+ feet of the wrong size stuff)
-David
Independence 31
Emerald
CaptnNero said:That's true, maybe the sail gear manufacturers aren't using the convoluted computer menus with the marketing pitch(es) leading to an outsourced service rep who doesn't speak or understand English well.
