Andrew Means
I'm not sure how the tiller-equipped E27s have it, but the backstay on my (wheel equipped) E27 splits into two cables about 8 feet from the transom and they terminates opposite of each other on the corners of the transom. There's a backstay adjuster that consists of two pulleys a fixed width apart, with a rope dangling down from them. You may be able to see them in this picture, depending on how much it's been resized.
The one thing that's completely missing is any way to keep the backstay tensioned; the rope just kind of dangles, and there's no block or cleat or anything to allow you to cinch it tight or ease it off. Those of you with this configuration, what do you do to adjust the backstay? I'm thinking just installing a little swivel block near where one of the backstay 'legs' connects, and then run the line back amidships on the transom with a cam cleat or something.
Now that I'm thinking about it, I think there's a chainplate type thing dead center on the top of the transom with one hole visible - although I can't confirm it by memory, I'll double check tomorrow.
