The original black engine panel frame was in pretty good shape. The panel-back has a slight rim around the mounting flange which leaves a shallow void behind the screw holes. I think this is why it often cracks beneath the screws. I filled this void with epoxy around all the screw holes. The black plastic itself is pretty flimsy and the panel was...
