Hello - I was hoping to tap the forum again for a little guidance. I've decided to replace the 3- group 31 batteries on Magellanes this spring... boat is wired with a house bank (2 batteries) and a separate switch for the engine battery. All 3 can be paralleled together.
The batteries on the boat now have lasted 7 seasons - they are "Seahawk" marine batteries, straight deep cycle batteries -- all batteries are the same. I'm inclined to follow the mantra of "if it ain't broke, don't fix it" and go with same set up -- however I can only find "dual purpose" batteries from the same manufacturer locally (after getting 7 seasons I am "brand loyal").
The "ratings" on the dual purpose seem very similar, cranking amps are about 8% higher on the dual purpose (875a vs 810a), Average minutes @23 amps is about 10% less (205a vs 225a).
Being that they are the same brand, similar ratings, I'm inclined to go with the Dual Purpose --- however I have heard that dual purpose can "fail" all of sudden vs deep cycle.
Any thought opinions and experience from the forum would be appreciated.
Dan
Dan
