If your coming to Chicago I can add to that pile !Me too. Maybe you and I should meet in Chicago so we can put the leftovers in one pile.
So far all I have made is a door for my workbench and a stool for the V berth. Outside the context of a sailboat it is weird stuff which fits in nowhere.
Yes, it did seem a bit involved, let’s say, but it does show a different way of doing the same thing (even though it’s not the best) but that holds true for a lot of things in life, doesn’t it? I do think that the way you show, Christian, is more suited to the conditions found on our boats. However if all you have on hand is a smaller piece (then the finish piece) of flat material then his way will still work but with more steps.He makes it complicated. I learned from watching the cabinetmakers of Tally Ho a simple and obvious method.
You collect some lengths of 1-2" wide thin material--typically door skin or Masonite--and hot-glue them together to fill the desired location. The resulting pattern is carried to the bench and traced, no need for measurements. You can build such a pattern to fit very complicated spaces. I wish I had known about this method years ago--it must be common knowledge among woodworkers.
