Having just had the E32-3 for a few months, I've only sailed her a handful of times and fixed a few things (eg. Boom Rehab and Stuffing Box, etc). After officially re-christening the boat this weekend, we took her out for a sunset sail around the SF Bay and the main sail got stuck on the way down. Just below the lower spreader there is a junction of two sail tracks which became misaligned by a few millimeters while underway. Upon ascending the mast, I found a screw in the upper track spinning freely with no purchase on threads behind the track. Maybe a backing plate fell off? or the hole is actually stripped? <shrug>
She's due for bottom paint and standing rigging inspection/replacement. I'm thinking to go ahead and take the plunge to haul out. Following is a full list of everything I'm thinking. Would love to hear any suggestions, thoughts or questions:
- Below Waterline & Hull
- Bottom paint
- Repaint transom
- Wetsand (or preferred method) above waterline to remove scratches, old name decal, smudges, and shadows (note: there is discoloration on the bow above the waterline from a previous hull repair); how to protect this after?
- Replace ALL seacocks & inspect thru-hulls for integrity
- Remove redundant seacock in head (if appropriate, I’m still trying to understand why there are two inline to the sink)
- Replace propeller (Bronze 2-blade 13-diameter 18-pitch)
- Re-caulk hull-strut interface
- Install zinc on strut (there isn't one currently)
- Check/replace cutlass bearing
- Check rudder packing gland and rudder play/alignment
- Replace stuffing box (or at least the hose and clamps connecting to stern tube)
- Clean up connection of transmission to prop shaft; add safety wires to set screws holding shaft
- Insides
- Replace marine toilet with updated Jabsco and associated sani hoses
- Standing Rigging
- Replace/tune standing rigging
- Replace halyards
- What are other options for the cable-to-rope jib/main halyards? Can this be transformed into all rope? Sheaves need to change?
- Replace spinnaker and spinnaker topping lift line halyards
- Repair/tune hydraulic backstay
- Fit/Install Tides Marine Sail Track on mast
- Return rigid vang to traditional boomvang -OR- adjust rigid vang to have more upward spring pressure
- Re-install traditional topping lift (depends on how rigid vang can be tuned)
- Electrical Aloft
- Replace masthead light with LED
- Replace foredeck/steaming light with LED
- Replace radio antennae with updated version?
- Replace wind vane with NMEA-capable version? (current is SeaTalk)
