Context: About to adjust the stuffing box on the E32-3 as it's dripping a little too much for my, albeit novice, taste. A drip every 2-3 seconds at the dock and a few drips a second underway in forward gear. I'm reading that it should be no drips at the dock and a 2-6 drips per minute with the propeller shaft turning [1][2]. I have no idea the last time the packing gland was adjusted. And, I don't know what kind of packing/flax is under the large nut or when it was last replaced.
I figured I would gather some materials and tools to replace the packing if the adjustments don't work, shaft gets too hot, dripping continues, <insert other signs that the packing needs replacement here>. Among the tools -- like two Ridgid E110 wrenches, packing extractors, infrared temp gun, PB blaster, stainless and bronze brushes, etc -- I'm purchasing some packing material and wondering what folks are using on their Ericson boats. I'm reading on MaineSail's site [3] the differences between packing material. I'm thinking about GFO for it's low temp and 'drip-less often' (NOT 'drip-free') capabilities. The only concern is graphite is high on the galvanic scale and could cause increased corrosion rates on anodes, propellers, and other things. I know from looking at the owners manual [2] the prop shaft is made of Monel, which should be somewhat more resistant to corrosion than other metals. For packing I'm looking at:
What are other folks using? Has anyone used GFO or other graphite options and, if so, what has been your experience with anode erosion and other corrosion shenanigans?
I'm also buying some new hose clamps to 'PTA' -- I don't like the rust showing on the forward clamps in the photo above and the safety wires are missing on the shaft set screw connecting to the transmission. I'm planning on throwing a smaller hose clamp on the exposed shaft as a safety retainer to avoid losing the prop and/or damaging the rudder if things go sideways. I'm going with these in varying sizes:
REFERENCES:
[1] https://www.windcheckmagazine.com/article/stuffing_box_maintenance/
[2] Ericson 32-3 Owners Manual, http://www.finessesailing.com/download/engine_/_mechanical/e32_manual.pdf (See page 3-7)
[3] Mainesail Article on Stuffing Boxes, https://marinehowto.com/re-packing-a-traditional-stuffing-box/
[4] Another EY.o thread, https://ericsonyachts.org/ie/threads/ericson-32-leaking-stuffing-box.13501/
[5] Another EY.o thread, https://ericsonyachts.org/ie/threads/hot-stuffing-box.14936/
[6] A blog post on stuffing box stuff, https://ericsonyachts.org/ie/ubs/novice-stuffing-box-analysis-inspection-discussion.799/
Amazon.com: Palmetto 1389 Series 100% GFO Expanded PTFE with Graphite Compression Packing Seal, Dull Black, 1/8" Square, 5' Length: Industrial & Scientific
Buy Palmetto 1389 Series 100% GFO Expanded PTFE with Graphite Compression Packing Seal, Dull Black, 1/8" Square, 5' Length: Saw Palmetto - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Amazon.com: Scandvik 08134037064 Stainless Steel Hose Clamp (SAE Size 40, 51-76 mm, 2" - 3", 12mm Band, 13676), 10 Pack: Automotive
Buy Scandvik 08134037064 Stainless Steel Hose Clamp (SAE Size 40, 51-76 mm, 2" - 3", 12mm Band, 13676), 10 Pack: Pipe Clamps - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
REFERENCES:
