GrandpaSteve
have you ever run it at a 5:1 scope?
Yes. Usually let out about 3:1 to set it, then 5:1 for normal anchoring. 7:1 was because I knew the bigger wind was coming that night. 5:1 seems like a steady set.
I found and use this for anchoring; https://chafepro.com/chafepro/chafe-pro-yacht-series/ and for both seasonal mooring pennants (primary and backup). Quite happy with it, user friendly and durable. I store xtras but just finished third season with original purchase. That's June to November on a mooring with no apparent degradation from abrasion tho the guards do get rather stiff from the weather/sun.good chafing gear,
I have skippered boats with a wide range of anchors. By far the spade style anchors (original)Rocna/Mantus/Sarca/Manson are far superior to all other designs as an all around primary anchor. especially if you re in a tidal area where the anchor must reset.We recently upgraded to a 44lb Vulcan on 100’ 5/16 G4 + 250’ 5/8” 8 plait nylon. Been very happy with it. Upgraded from a 35lb CQR on 50’ 3/8” BBB + 150’ 5/8” 3 strand nylon. The new chain is way easier to haul even with the heavier anchor and the 8 plait stacks and runs really cleanly from the anchor locker. While I understand @Puget sailor concern about chafe I‘ll take the ease of handling 8 plait every day and make sure we have good chafe gear out when it’s blowing.
www.morganscloud.com
Looks like an interesting article, unfortunately blocked by a paywall. The image looks similar to my danforth that I bent when it was jammed in some rocks and the tide turned.For anyone who likes to geek out on anchors here's a good followup article on a Spade failure.
Spade Anchor Failure, Update and Summary
A follow-up, with some significant changes, to our article on a failed Spade anchor.www.morganscloud.com
The boat came with two bags of anchor rode. Both had roughly 30' of chain, and the rest (200-250?') three strand nylon rope. I don't recall the lengths anymore, Marina Hell Rey baywatch cut both of them and towed Cinderella to the Police dock. They claimed Cinderella was "drifting" in the only allowable anchorage area. They also reported that the anchors were too well set to lift so they had to cut the rode. Our garmin was updating the boat's position the entire time, interestingly our position hadn't changed until the boat was taken under tow. The rope diameter was different, one was 5/8" the other was 1/2". When we anchored in the PNW before we went cruising, we used the 5/8 rode. We often used both for bow/stern anchoring.Thanks @Gaviate ! A simple solution to the chafing question was/is very welcome.
@p.gazibara -- It looks like I understand Ok re: 15kg Rocna/Matus/etc... but
--> What dia. and type of rode do you use (and, maybe, length/dia of chain?) For instance, if 1/2" 3-strand is too little, (at least per @Puget sailor, whose concern makes sense) then is 5/8" rode what you use? Particularly curious what you are using, since my boat is similar size to yours.
--> Any other E34 owners... how much rode (and what dia) can/do you cram into that (pretty small) anchor locker? I am not sure how I'd get 300' of 5/8" 3-strand in there; that stuff is big. The braided seems to lay down better, so maybe that would work.
Thanks again!
As usual, wise words from Christian. We SO over-provisioned with our anchoring tackle when we first bought "Radiance." We've literally anchored twice in four years. And one of those times was to practice - you guessed it - anchoring. We are mooring ball and dock people. So off went the 200' of chain, replaced by 250' feet of eight plait rode and just 50' feet of chain. I've even been toying with the idea of offloading the emergency tackle that hasn't been removed from its bag in the stern laz since it went in there. (Of course, I know exactly what will happen the first time out if I actually follow through with that.)I think it depends on use. I have 200+ feet of line and 60 feet of chain, no windlass. Any anchoring for me would be an emergency.
Everything changes if sailing around the world, or if you happen to have no engine (or expect that), or if your cruising grounds have a nasty lee shore, or the local situation means well equipped boats tend to have special gear. Such special gear varies between Maine, Chesapeake and Patagonia.
Do you ever anchor overnight in difficult places of high wind, sea, and bad holding? Is the water deep or shallow (affects scope). Got a windlass?
If like me, you avoid anchoring, then it's probably a scenario of just waiting for a tow, or stopping for lunch. So minimal works.
It helps to consider that for most of us, anchorages need to be secure, protected and reliable. Even then it's hard to sleep. Even in a mudhole on a bay, and certainly off any California coast or island.
My argument really comes down to the question, what role does anchoring have in your plans? If important, then gear up. If lunch only, a shrug. .
