Than makes sense: maybe …position a socket on the bolt via the access hole in that port side locker, poke a long extension rod through the hole by the mast, into the socket, then tighten the bolt via that extension rod. ???I believe that small hole in front of the mast is used to tighten the keel bolt. I think there is a posting about it somewhere on this site with a photo of it being done, but I maybe wrong. Maybe someone else seeing this reply has a better memory then me.
OK, I found what I thought I remembered. When you click on the link below and look at the photos you’ll see what I was referring to as far as access to the forward keel bolt.Than makes sense: maybe …position a socket on the bolt via the access hole in that port side locker, poke a long extension rod through the hole by the mast, into the socket, then tighten the bolt via that extension rod. ???
It is deceptive and considering that when I'm on board I'm usually with my "first mate" so it's sometimes close quarters. Good thing we like each other!Almost looks too confining to actually walk on and live on, when viewed that way. I recently had our refinished sole pieces laid in our garage and it was difficult to believe that these were the roomy-enough walking surface in a 34 foot sailboat.
What with all of the actual "elbow room" inside the cabin, the T&H sole area is rather deceptive, isn't it?
That's what I did as well, and took a rasp down to the boat for any touch ups as needed when dry fitting. It doesn't have to be pretty.I think I did a good deal of shaping the edge with a sander.
Yes you can do it this way. I think at the factory it was done on a shaper with a large table.While examining the old T&H sole I removed from my boat (those pieces that came up in one piece) I noticed that the outside edges (except for those edges that butt into another section of the sole) are rounded underneath and the look to be done with a router bit. This looks necessary in order to have a correct fit where the T&H meet the TAFG which is also rounded at that point. My question is how is that done on a 1/4" thick piece of T&H plywood? The only way I could see would be to use the 1/4" plywood template again as a guide for the rounder/beading bit after it was used to cut the piece but in this case the template wound be on the bottom with the cut T&H on top but upside down with the top surface facing the template. The two pieces would be matched up (to sort of form a 1/2 sheet of plywood) and then I would round the bottom edge of the T&H using the template as my guide. I hope this makes sense! Attached a diagram of what I'm trying to describe.
Yes, many choices and I have a hard time choosing what shirt to wear in the morning too so this one’s gonna be hard. Actually I think that I’m going with Minwax polyurethane, which is oil based and suppose to be very durable, in either satin or semi-gloss. Gloss is appealing, yes, but I think that I need something that takes more of a beating without showing scratches. I can always re-coat in gloss if I change my mind. Still need to re-condition the bilge covers. Working one the first one to see how far off the finish might be compared to the new T&H and if it’s not right then I’ll make a new set which will be a good winter project.Looks great. Now you must confront the final step.
My choice is glossy spar varnish, seven coats (first time). But there are many choices.
