Like most of us, I have water which regularly enters the boat through the mast on my E32-3. There is no gutter around the mast step so the water runs across the cabin sole to the starboard side of the boat and seeps into the edge of the flooring where it meets the fiberglass gelcoat at the base of the starboard settee/berth. After watching this minor phenomenon through several rain storms noticed this:
Okay, fine - there's some water trapped under the floor. But, I've also noticed some of the flooring is a bit soft. The section is directly under the small 3/4" shelf of fiberglass that runs over to make the front edge of the shower bilge. I think water from the mast might be running under the floor along this tiny shelf and causing the wood to rot from underneath.
I'd like to examine the underside of the flooring, but I can't find any screws, wood plugs, or anything other fastener holding the sections of teak down. And when I pull up on the flooring at the bilge openings.. no budge.
I'm trying to think of this problem in two pieces:
- How to funnel water from the mast into the shower bilge
- How to repair the flooring without destroying it
