    EY.o April Zoom Meeting
What's the most useful modification you've made....
fidji
Eric
Hi Frank that is the most useful modification I made. You will note that when the first step is folded down the spaces between each step are equals. The hinge fitting is like the ones we use on bimini tops and split open in two, but I changed the set locking screw by a mechanical screw with the same thread but passing through the wall of the inside tube.
Eric Meunier
Decision
E 35 mkIII
fidji
Eric
I took a look at one of the colored brochure of a E30+ and I'm sure Frank you can build the same folding step ladder as mine and that way saving your marriage :egrin:
Good luck!
Eric
treilley
Looking through this thread I realised I never updated it with modifications I made to our Eriecon 35-3. Here are my favorites:
- Bigger sink with pullout sprayer faucet and slider trash bin door.
- Rebuilt Meriman pedistal with custom made top plate, drink holder and chartplotter mount.
fidji
Eric
Mr. Treilley, can you tell me what model or any other information that I need to be able to buy the same sink as you put in your Ericson 35, How deep is that sink?
Thank's
Eric
treilley
Both foot pumps remain along with the 2 spigots. One is for icebox pump out and the other is for fresh water pumping. I removed the connection to the saltwater as we never used it and feel it was not well suited for a coastal cruiser with 100 gallon water capacity.
Randy Rutledge
Key holder and other stuff
Some of the mods I have found useful are An auxiliary engine panel with an ignition and start switch that are only active when the blower is on, The engine cover front panel came loose from the top and I have found leaving it that way makes accessing the engine more simple as it is now two flat panels instead of the L shaped cover to handle and place while servicing the engine, I installed a DVD and flat screen TV for evenings at the dock, Note that I am watching a sailing "instructional video" and the ignition key holder shown in one of the pictures has multiple uses.
lbertran
Sink Project
Hi, Tim-
I'm thinking about switching out my sink for the larger one from Elkay. How did you remove the spot welded mounting tracks? I was looking at one at Home Depot yesterday and a method for non-destructive removal was not immediately obvious to me. I also wondered if the Scandvik sinks come without those tracks.
Any info on your methodology would be appreciated!
Hi, Tim-
Until Tim checks in....
I removed 4 of the six original studs on our galley sink with a cutting wheel on a Dremel tool. I found that the sealant held the sink tenaciously and only used a couple of studs as locators when it was rebedded in new sealant.
treilley
Hi, Tim-
Laura, the Elkay was a fairly cheaply made sink so I was able to use a very sharp chisel and cut through the spot welds to get the tracks off. Then I had SS bolts welded on the four corners and used fender washers to hold it down with some closed cell insulating foam tape under the edges. I also slightly bent the sink so the edge was bowed down slightly along the length of each edge. This insured that the edges would sit snug againet the coutertop when I tightened the corner bolts.
I just did this same upgrade on my present boat and used a Kohler sink that is much better quality. On that one I had to fold the track down to where it would not interfere with the mounting on one edge. The other edges I secured with the stock mounting tabs. I also used the closed cell foam tape on this one.
Akavishon
Here's a very simple but VERY useful project :)
Zoran
mann
Inactive Member
adding a fridge to my e29
I had an idea that I could get a dorm fridge and install it in the ice box. I was surprised that it really didn't have a compressor. It only had a small cold plate hooked to a larger heat dissipator. I was able to mount the thermostat inside the box and a door switch to turn on a light. I haven't worked out the bugs yet but I believe it will work. The cold side is working but I don't think I am moving enough air across it. Lots of condensation. All for less than 50 dollars.
Steve A
chart table
I took out the quarter berth and built in a chart table with shelves for nav books and computer/printer. also has a foul weather gear locker under it. Seat is raised so I can see out the windows.nav.jpg
Steve A
aft deck
I decked over the aft cockpit, as I prefer a tiller( my boat's only 24'LWL, so she sails like small boat) and built in deck gear and propane lockers.aftdeck2.jpg
