(Yacht Specialties/Merriman binnacle steering manual: https://ericsonyachts.org/ie/resources/merriman-binnacle-catalog.187/ )
( Edson pedestals: https://backwinded.wordpress.com/20...iesel-engines-throttle-shift-and-stop-cables/ also Edson 335 pedestal with Yanmar 3YM30 https://ericsonyachts.org/ie/ubs/e38-200-quincy-engine-control-replacement.999/ )
This pedestal is on a 1984 Ericson 381, but the general idea is the same on all YS/Merriman pedestals.
The job isn't difficult, but there are many pieces. A photo record is useful when reassembling.
The sticking point is often seized stainless machine screws in old aluminum castings. A penetrating lube such as "PB Blaster" is required, along with patience and the usual bag of tricks.
The following sequence illustrates dismounting the entire pedestal from the boat, and begins after removal of the pedestal guard, steering wheel, and compass. When replacing shift and throttle cables only Steps 2-4 are necessary.
1. Remove the large stainless countersunk bolts from the deck. The nuts beneath also secure the quadrant sheaves assembly box. Let it sag, but note how cables, chain and 12v wires are routed through their openings.
2. Remove four stainless machine screws from the shift housing collar ring. Set ring aside.
3. Remove throttle and gearshift arms. They are fixed to bronze levers visible in the rectangular opening. Loosen the set-bolts and pull the throttle and gearshift arms out horizontally.
3A. Remove the four large stainless machine screws securing the shift lever housing. Red arrows in photo above.
4. Pull the shift lever housing up about a foot. There should be enough slack in the (Morse or Teleflex brand) control cables to permit this. If not, detach the control cables from transmission and engine. It's a good idea to replace the cables with new ones anyhow The difference is butter-smooth rpm control and gear shifting.
For good diagrams of the control cable connections see this archived catalog: https://ericsonyachts.org/ie/resources/merriman-binnacle-catalog.187/
Installation illustration below is from: https://ericsonyachts.org/ie/resources/yacht-specalities-catalog-4.180/
5. Detach the shift lever housing from the cable connectors and set it aside.
(continued)
(continued)
