Jeff & Donna, new owners 7/21
This is a continuation of a conversation started in:
ericsonyachts.org
Thanks for your input on my project.
@Bolo @Kenneth K @Shannon & Doran Jones @Loren Beach @Chschaus @peaman
I was planning on just reinstalling the sole as close as possible to what came out of the factory. Based on your input I’m going to make it removable. I thought it might be worth starting a new thread with some of the challenges I’m specifically having with the 35-3.
These have been my references thus far:
http://www.tkronaboat.com/cabin-sole-replacement.html E35-3
on a 35-3 https://ericsonyachts.org/ie/threads/my-3-4-solid-marine-holly-teak-sole-going-in-this-week.18361/
ericsonyachts.org
ericsonyachts.org
https://ericsonyachts.org/ie/threads/cabin-sole-replacement.2423/ bamboo
https://ericsonyachts.org/ie/threads/ericson-38-200-cabin-sole.16568/ lots of pictures
https://ericsonyachts.org/ie/threads/cabin-sole-progress.4717/ E35-3
ericsonyachts.org
ericsonyachts.org
ericsonyachts.org
ericsonyachts.org
ericsonyachts.org
ericsonyachts.org
ericsonyachts.org
repair panel: https://ericsonyachts.org/ie/ubs/thelonious-ii-delaminated-floorboards-4-minute-video.382/
varnish & epoxy
Weekend projects
We successfully installed a new water pump today and will be installing the new set up for the chartplotter tomorrow. What's on your weekend boat project list?
Removal of Glued-Down Cabin Sole [Master Thread]
Unfortunately, my boat is one of the models where Ericson glued down the teak and holly sole. Has anyone ever removed it on a similar boat and how big of a job is it?
E38 Cabin Sole
Hi everyone can anyone tell me if the cabin sole on a 1988 or 1989 E38 is glued or just screwed down or, it would depend on who was doing that job on a given day at the factory?
Need Help Cutting Teak and Holly Panels
Getting ready to install a new sole in my 87 34-2. Have sealed the panels with CPES and am now at the stage where I can begin slicing the sheets up into (10) usable pieces. I made patterns of the existing floor boards out of 4mill plastic film from an art supply store and marked where all of the...
E381 - New Teak & Holly Sole & Cupboard
This winter I finally got around to starting the cosmetic to-do projects that the admiral has been pushing me to do since day one of purchasing my E38. Some of the sole in the galley, head, quarter berth, and companionway entrance had been badly...
e381 Cabin Sole Replacement
I bit the bullet and had the cabin sole replaced on the e381. I was concerned about how difficult it was going to be to get the old floor out but we were able to get every piece out in good enough shape to use it as a template. All the trim was removed stripped, sanded and refinished. The...
Matching Replacement Sole Color (stain? )
After some extensive and exhausting research and trials, we are still unable to get a decent match to the original veneer in our 1983 38 ft. It's making us crazy as we really don't want to pull up the pieces that are undamaged, and it would be great if the sole didn't look like a coloring...
cabin sole removal?
I have a 1987 E34; the shorter keel model. Does anyone know if the cabin sole is glued to the hull? I do not seem able to remove it. Thanks in advance!!!
Varnished Cabin Sole (again) Pictures
Here are the missing pictures from the Varnishing Cabin Sole (again) thread. http://www.ericsonyachts.org/infoexchange/showthread.php?13839-Varnishing-cabin-sole-(again)
O34 - The Olson 34 (Partial) "TAFG" revealed
After way over a decade it's time to sand and revarnish the T&H sole pieces. I removed them today and brought 'em home. A few bronze screws did twist off, evidently being gripped really tight by the fibers in the FRP flanges. I will try to lube...
varnish & epoxy
