My original mast head anemometer has slowed to an unbalanced crawl. To make matters worse, a big bird tried to sit on it and when it spun on him, his frantic flapping in getting away, knocked off the directional fin.
The dilemma now is what to do. The other original instruments still work well - boat speed and depth show accurately on the main unit as well as on the binnacle repeater. Expense wise, getting a plug in replacement anemometer would be the smart move, if I can find one. Alternatively, the Raymarine ST60wind speed set up looks promising, but would add a stand alone instrument to the existing data marine boat speed and water depth.
For not a lot more dollars the ST60 tri data set up would get me into the modern age.
Another option would be adding a depth and speed transducer to my Lawrence 527 igps plotter/sounder. I could use the present speed transducer thru hull opening. Then I would just need to get a stand alone wind speed unit. If I did that, I would remove the existing Data Marine instruments.
Trying to keep it simple, I've contacted DMI about getting a rebuild kit for the anemometer, and although they took my credit card information and agreed to send me one, they have not done so. They 'lost' the information in the initial order, and then when I phoned weeks later, despite being promised that the item would be shipped that day, there's been no sign of it. I phoned again weeks later only to be told the item had been shipped. There's been no charge against my credit card by DMI in all that time, so I can only speculate about what is really going on here.....
Any thoughts or recommendations will be most appreciated.
Tor
Decisions, decisions.
Tor
